Hi friends,
I am going to start the semi restoration of my av78. One question to arrives to my mind if is there any way to lock the utils box behind the seat.
Well this one of the multiple questions I hope you solve on my "spanish" bleue!
Mercy beaocup
coffre outils av78
Re: cofre utils av78
Hi!
You're speaking about the tools box? It's closed with a special bolt , with a plastic cap (black or beige)
¿Hablas de la caja de herramientas? Se cerra con un pernito cubierto de plástico de color negro o beige.
AV31, Mobyx X7 (couleur saumon), AV85, N50, M7, AV 92 GT, 51V
Re: coffre outils av78
Non Christophe 44, il s'agit d'une AV78. Selon l'année c'est soit une petite sacoche en cuir ou skaï sous la selle , soit une boite cylindrique métal sur la vis de serrage de selle, avec écrou prisonnier métallique dans le couvercle.
comme ça:
http://www.bibliotobec.org/gallery/pict ... tegory/167"
ou comme ça:
51AV3, quelle est la tienne?
witch one is on your bike?
comme ça:
ou comme ça:
Hi,
My one is the second one. I am refering to piece number 15637 of this page: http://www.bibliotobec.org/gallery/pict ... tegory/167"
Mercy beacuop por le aid!
Sorry Pierre,
I didn´t explain well: what I want to know is a way to lock the tool box. I want to keep the documents of the moped in the box, and I want to have it locked to prevent against theafs!!!!
Do I explanied well this time??
Mercy
Mercy
Ha, OK you explain well. I don't know a lock for this tool box. Exept drill two holes to hang a lock, but it's a pity.
